Cisco 1751 configuration and call transfer.
Discussion in '3CX Phone System - General' started by Urbok, Nov 25, 2007.
  1. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    hello cisco experts :).
    I've correctly installed and configured a 2 port wic fxs card of my cisco 1751.
    now I've 2 extensions working great.
    my big problem now it's call transfer.
    How do I transfer a call from extension to another extension?
    PS on port 2/0 i've connected a fax. on 2/1 a standard analog phone.
    here is the voip configuration on cisco router:
    voice-port 2/0
    no vad
    cptone IT
    timeouts wait-release 15
    bearer-cap Speech
    station-id number 1003
    caller-id enable
    voice-port 2/1
    input gain -6
    output attenuation -6
    no vad
    cptone IT
    bearer-cap Speech
    station-id number 1004
    caller-id enable
    dial-peer voice 1003 pots
    destination-pattern 1003
    fax rate fax
    port 2/0
    authentication username 1003 password XXX
    dial-peer voice 1004 pots
    destination-pattern 1004
    port 2/1
    authentication username 1004 password XXX
    dial-peer voice 10000 voip
    destination-pattern .T
    session protocol sipv2
    session target ipv4:192.168.25.101
    dtmf-relay rtp-nte
    codec g711ulaw
    fax rate 14400
    fax protocol pass-through g711alaw
    gateway
    timer receive-rtp 1200
    sip-ua
    registrar ipv4:192.168.25.101 expires 3600
    sip-server ipv4:192.168.25.101
  2. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    transfer
    Urbok,
    I am inclined to think this is not a Cisco router issue, but rather a function of the phone. Also not sure but I would think the analog phone would need to send a transfer signal that could be translated to a SIP signal. Does the analog phone have a transfer function? Can you do a "debug dialer" to see what happens when you use the function?
    Mark
  3. alicic
    alicic New Member
    Oct 3, 2007
    119
    Hallo,
    If your pfones support call transwer then it should be configured in cisco as follows
    conf t
    telephony-service
    transfer-system full-consult
    transer-pattern .T
    it should then transwer the calls,
    regards
  4. Urbok
    Urbok New Member
    Jul 14, 2007
    120
    what do you mean for "pfones"??
    my phones are standard analog cordless with "R" flash key.
    with other ata adapters to transfer a call I do "R" + extension.
    with cisco the flash key do nothing.
