cisco 504 idle screen
Discussion in '3CX Phone System - General' started by aftermarket, Jul 20, 2010.
  1. aftermarket
    May 13, 2009
    84
    does anybody know how to make the fourth soft key be the missed call key instead of the dnd key, this is what i have at the moment
    em_login|1;acd_login|1;acd_logout|1;avail|3;unavail|3;redial|5;resume|5;dir|6;cfwd|7;chkcfwd|7;dnd|8;chkdnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout
  2. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    When you have a missed call it automatically does this, but I assume you want this at all times. I have a 504 in my office, I will play around with this and let you know what I see.
  3. aftermarket
    May 13, 2009
    84
    ok thanks for doing that. do you have your 504 set up to do anything else special like global phone book or xml services?
