Cisco 7937G Conference Room Phone Compatible?
Discussion in '3CX Phone System - General' started by ahkim, Feb 21, 2018.
  1. ahkim
    Jan 31, 2017
    5
    The Cisco 7937G does not seem to be supported by 3CX, does anyone know of a workaround? It's a great speakerphone that was from our previous system so I'm hoping there's a way.
    It's interesting that the Polycom SoundStation IP7000 looks identical to the Cisco but the IP7000 is supported.
    Thank you.
