Cisco 7940 7960 config SIP Firmware POs3-08-2-00
Discussion in '3CX Phone System - General' started by AWnet, Nov 22, 2007.
  1. AWnet
    Nov 22, 2007
    Does anyone have any complete SEPMAC.cnf.xml, SIPdefault.cnf, SIPMAC.cnf config files they can submit.
    I have created the above but when I power the phones up they get to the point of loading SIPMAC.cnf and reboot. If I pause the TFTP server for 30 seconds, then restart TFTP they load the config and work.
    I also do not believe that the phones are reading the SIPDefault.cnf file as they were not picking up settings in the SIPDefault.cnf file but if I moved to the SIPMAC.cnf file then the phones apply the settings.
    SEPMAC.cnf.xml
    <device>
    <deviceProtocol>SIP</deviceProtocol>
    <sshUserId>awnet</sshUserId>
    <sshPassword>aw0rd1</sshPassword>
    <devicePool>
    <dateTimeSetting>
    <dateTemplate>D-M-Y</dateTemplate>
    <timeZone>GMT Standard/Daylight Time</timeZone>
    <ntps>
    <ntp>
    <name>192.168.100.14</name>
    </ntp>
    </ntps>
    </dateTimeSetting>
    <callManagerGroup>
    <members>
    <member priority="0">
    <callManager>
    <ports>
    <ethernetPhonePort>2000</ethernetPhonePort>
    <sipPort>5060</sipPort>
    <securedSipPort>5061</securedSipPort>
    </ports>
    <processNodeName>192.168.100.14</processNodeName>
    </callManager>
    </member>
    </members>
    </callManagerGroup>
    </devicePool>
    <sipProfile>
    <sipProxies>
    <registerWithProxy>true</registerWithProxy>
    </sipProxies>
    <enableVad>false</enableVad>
    <!—Note – This following may need to be just g711 in later firmware versions -->
    <preferredCodec>g711</preferredCodec>
    <natEnabled></natEnabled>
    <phoneLabel>Robert</phoneLabel>
    <sipLines>
    <line button="1">
    <featureID>9</featureID>
    <featureLabel>100</featureLabel>
    <proxy>192.168.100.14</proxy>
    <name>100</name>
    <displayName>Robert</displayName>
    <authName>100</authName>
    <authPassword>100</authPassword>
    <messagesNumber>999</messagesNumber>
    </line>
    <line button="2">
    <featureID>21</featureID>
    <featureLabel>SpeedDial</featureLabel>
    <speedDialNumber>5551234</speedDialNumber>
    </line>
    </sipLines>
    <dialTemplate>DRdialplan.xml</dialTemplate>
    </sipProfile>
    <commonProfile>
    <phonePassword></phonePassword>
    </commonProfile>
    <loadInformation>POS3-08-2-00</loadInformation>
    <versionStamp></versionStamp>
    <directoryURL></directoryURL>
    <servicesURL></servicesURL>
    </device>
    SIP Default.cnf
    image_version: "POS3-08-2-00"
    #Proxy Server
    proxy1_address: "192.168.100.14"
    #Proxy Server Port (default-5060)
    proxy1_ports: "5060"
    #Proxy Registration (0-disable (default), 1-enable)
    proxy_register: "1"
    #Phone Registration Expiration [1-3932100 sec] (default 3600)
    timer_register_expires: "60"
    #Codec for media stream (g711ulaw (default), g711ulaw, g729a)
    preferred_codec: "g711"
    SIPMAC.cnf
    #Line 1 appearance
    line1_name: 100
    line2_displayname: Rob
    # Line 1 Registration Authentication
    line1_authname: 100
    #Line 1 Registration Authentication
    line1_password: 100
    # Line 2 Setting
    line2_name: ""
    #Line 2 Display Name
    line2_displayname: ""
    #Line 2 Registration Authentication
    line2_authname: "UNPROVISIONED"
    line2_password: "UNPROVISIONED"
    #Proxy Server
    proxy_register: "1"
    # Emergency Proxy
    info proxy_emergency: "192.168.100.14"
    proxy_emergency_port: "5060"
    # Backup Proxy info
    proxy_backup: "192.168.100.14"
    proxy_backup_port: "5060"
    # Outbound Proxy info
    outbound_proxy: ""
    outbound_proxy_port: "5060"
    # NAT/Firewall Traversal
    nat_enable: "1"
    nat_address: ""
    voip_control_port: "5060"
    start_media_port: "16384"
    end_media_port: "32766"
    nat_received_processing: "1"
    # Phone Label (Text desired to be displayed in upper right corner)
    phone_label: "ROB"
    #Has no effect on SIP messaging
    # Time Zone phone will reside in
    time_zone: "GMT Standard/Daylight Time"
    # Telnet Level (enable or disable the ability to telnet into this phone
    telnet_level: "2"
    # 0-Disabled (default), 1-Enabled, 2-Privileged
    # Phone prompt/password for telnet/console session
    phone_prompt: "Go Away"
    #Telnet/Console Prompt
    phone_password: "aw0rd1"
    #Telnet/Console Password
    # Enable_VAD (1-enabled, 0-disabled)
    enable_vad: "0"
    # Network Media Type (auto, full100, full10, half100, half10)
    network_media_type: "auto"
    user_info: phone
    # URL for external Directory location
    #URL for branding logo to be used on phone display
    #logo_url: "http://10.0.1.3/10-20logo.bmp"
    Any help appreciated.
    rob- AWnet
