Cisco 7940 Company Phonebook
Discussion in '3CX Phone System - General' started by rfsHugh, Jul 28, 2014.
  1. rfsHugh
    Jul 24, 2014
    6
    I have several 7940s set up and running fine with 3CX, the only remaining issue is to do with integrating with the company phonebook. The phone is only able to display the first 32 entries of the phonebook, pressing the 'next' softkey briefly displays 'contacting http server' but then nothing happens.
    I understand that this is a feature implemented by cisco to reduce network load and that additional coding is required to allow the 'next' key to function properly. However I have no idea how to proceed. If someone could point me in the right direction of where the coding changes should be made it would be greatly appreciated!!
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi, we are working on a workaround to this limitation of 32 entries, keep informed through blog for next releases.
  3. rfsHugh
    Jul 24, 2014
    6
    That's great to hear, looking forward to the future release!
