cisco 7940 how to add ctu 24 ring tone?
Discussion in '3CX Phone System - General' started by aftermarket, May 21, 2009.
  1. aftermarket
    May 13, 2009
    84
    hi
    finally got the phone booting from tftp however when i go to ring tones there is only the option for two ring tones. i have tried adding the ringtone.dat file but its not worked?
  2. aarevalo
    Aug 30, 2008
    8
    How are you tring to do this? via tftp? I had the CTU .cpm ringtone some time ago but I lost them. the way you have to do it is doing an tftp server and adding the ringtone names to the ringtone.dat file (the ringtone.dat and the ringtone should all be in the same place) restart your phone, point it to the tftp server and voila.
    Any question let me know
  3. aftermarket
    May 13, 2009
    84
    hello
    thanks for that i've done it now. do you know how to configure the services/messages and directories buttons on these phones?
    thanks
  4. aarevalo
    Aug 30, 2008
    8
    I don't believe this is posible with 3CX (can someone confirm that please?) Cisco has some application that you have to download and it will basically setup the website where you would point the phone for the extra services and directores that you would want)
  5. home
    Feb 25, 2009
    31
    The Directories is possible, I have been experimenting for a couple of months now, I am now looking at the services but no luck yet.
    I downloaded Fastream IQ Web/FTP Server and setup, you will also need a copy of Edxor (for writing xml files ), then you edit the SIPDefault file in your TFTP server, pointing the Directory at the Web Server.
    The xml format you need for the directory are, this need to be written using Edxor,
    <CiscoIPPhoneDirectory>
    <Title> </Title>
    <Prompt> </Prompt>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    <DirectoryEntry>
    <Name> </Name>
    <Number> </Number>
    </DirectoryEntry>
    This gives you a 32 entry directory. When you press the Directories button, you should now have a 5th option "External Directory",
    press and there you go.
  6. aftermarket
    May 13, 2009
    84
    hi thanks for that and that will work even though i've converted it to sip? also will the phone pick up numbers that are coming in and assign them a name if its in the phone book?
    thanks
  7. home
    Feb 25, 2009
    31
    It works with SIP, I have over a dozen 7940G's working, if you enter the correct value for "Messages" in your SIPDefault you can go straight to voicemail by pressing the Message button, as I do not have caller ID at home I can cannot say weather it will recognize a number and display the directory entry.
  8. aftermarket
    May 13, 2009
    84
    what the correct value for the message button to go through to vocie mail sorry i'm new to all this!!
    thank you
  9. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    Same as the default 3CX value - usually 999
  10. aftermarket
    May 13, 2009
    84
    ok i have changed this to 121 what would be the code that i would put in the sipdefault file? sorry for asking question on question new to all this and it been one long headache thats slowly getting better!
  11. home
    Feb 25, 2009
    31
    Assuming you have entered "121" in the Message slot in your SIPDefault.cnf file and also in the Voice Mail Menu Extion Number in 3CX, all you need do now is press the Envelope button on your phone and enter your pin when prompted, also red light should show on handset when messages have been left.
    Hope this helps.
  12. aftermarket
    May 13, 2009
    84
    theres no message code to add that into in my sipdefault. do you know what it would be?
    thanks
  13. home
    Feb 25, 2009
    31
    Here's a copy of my template,
    image_version: "P0S3-07-4-00";
    proxy1_address: "10.1.18.100";
    proxy2_address: "";
    proxy3_address: "";
    proxy4_address: "";
    proxy5_address: "";
    proxy6_address: "";
    proxy1_port: "5060";
    proxy2_port: "";
    proxy3_port: "";
    proxy4_port: "";
    proxy5_port: "";
    proxy6_port: "";
    proxy_register: "1";
    time_zone: "EST";
    dst_auto_adjust: "1";
    dst_start_month: "April";
    dst_start_day: "";
    dst_start_day_of_week: "Sun";
    dst_start_week_of_month: "1";
    dst_start_time: "02:00";
    dst_stop_month: "October";
    dst_stop_day: "";
    dst_stop_day_of_week: "Sun";
    dst_stop_week_of_month: "8";
    dst_stop_time: "02:00";
    date_format: "M/D/Y";
    time_format_24hr: "0";
    local_cfwd_enable: "1";
    directory_url: "";
    messages_uri: "2000";
    services_url: "";
    logo_url: "";
    stutter_msg_waiting: "0";
    sync: "0000200155330856";
    telnet_level: "1";
    autocomplete: "1";
    call_stats: "0";
    Domain_Name: "";
    dtmf_avt_payload: "101";
    dtmf_db_level: "3";
    dtmf_inband: "1";
    dtmf_outofband: "avt";
    dyn_dns_addr_1: "";
    dyn_dns_addr_2: "";
    dyn_tftp_addr: "";
    end_media_port: "32766";
    http_proxy_addr: "";
    http_proxy_port: "80";
    nat_address: "";
    nat_enable: "0";
    nat_received_processing: "0";
    network_media_type: "Auto";
    network_port2_type: "Hub/Switch";
    outbound_proxy: "";
    outbound_proxy_port: "5060";
    proxy_backup: "";
    proxy_backup_port: "5060";
    proxy_emergency: "";
    proxy_emergency_port: "5060";
    remote_party_id: "0";
    sip_invite_retx: "6";
    sip_retx: "10";
    sntp_mode: "directedbroadcast";
    sntp_server: "0.0.0.0";
    start_media_port: "16384";
    tftp_cfg_dir: "";
    timer_invite_expires: "180";
    timer_register_delta: "5";
    timer_register_expires: "3600";
    timer_t1: "500";
    timer_t2: "4000";
    tos_media: "5";
    voip_control_port: "5060";
  14. Discovery Technology
    Apr 19, 2008
    278
    It's in the SIP{MAC}.cnf file...
    # Voicemail setup
    messages_uri: 121
