Cisco 7941 Phone Issues
Discussion in '3CX Phone System - General' started by IKWeb, Jun 3, 2012.
  1. IKWeb
    Jun 3, 2012
    8
    Hello All
    Well after spending hours working out how to send a config to a Cisco 7941 I have managed it.. :)
    One problem tho, the routing of calls etc works fine, but I cant get the handset on the phone to work... when it calls I can only answer calls by speaker, and also make calls this way. Below is my config, if anyone can help I would be very very greatful.
    <device>
    <deviceProtocol>SIP</deviceProtocol>
    <sshUserId>admin</sshUserId>
    <sshPassword>cisco</sshPassword>
    <devicePool>
    <dateTimeSetting>
    <dateTemplate>D-M-Y</dateTemplate>
    <timeZone>Greenwich Standard Time</timeZone>
    <ntps>
    <ntp>
    <name>130.88.203.12</name>
    </ntp>
    </ntps>
    </dateTimeSetting>
    <callManagerGroup>
    <members>
    <member priority="0">
    <callManager>
    <ports>
    <ethernetPhonePort>2000</ethernetPhonePort>
    <sipPort>5060</sipPort>
    <securedSipPort>5061</securedSipPort>
    </ports>
    <processNodeName>192.168.0.59</processNodeName>
    </callManager>
    </member>
    </members>
    </callManagerGroup>
    </devicePool>
    <sipProfile>
    <sipProxies>
    <registerWithProxy>true</registerWithProxy>
    </sipProxies>
    <enableVad>false</enableVad>
    <preferredCodec>g711</preferredCodec>
    <natEnabled></natEnabled>
    <phoneLabel>Danny Office</phoneLabel>
    <sipLines>
    <line button="1">
    <featureID>9</featureID>
    <featureLabel>100</featureLabel>
    <proxy>192.168.0.59</proxy>
    <port>5060</port>
    <name>100</name>
    <displayName>100</displayName>
    <autoAnswer>
    <autoAnswerEnabled>2</autoAnswerEnabled>
    </autoAnswer>
    <callWaiting>3</callWaiting>
    <authName>100</authName>
    <authPassword>100</authPassword>
    <sharedLine>false</sharedLine>
    <messageWaitingLampPolicy>3</messageWaitingLampPolicy>
    <messagesNumber>800</messagesNumber>
    <ringSettingIdle>4</ringSettingIdle>
    <ringSettingActive>5</ringSettingActive>
    <contact>200</contact>
    <forwardCallInfoDisplay>
    <callerName>true</callerName>
    <callerNumber>false</callerNumber>
    <redirectedNumber>false</redirectedNumber>
    <dialedNumber>true</dialedNumber>
    </forwardCallInfoDisplay>
    </line>
    <line button="2">
    <featureLabel>101</featureLabel>
    <port>5060</port>
    <name>101</name>
    <displayName>101</displayName>
    <autoAnswer>
    </autoAnswer>
    <authName>101</authName>
    <authPassword>101</authPassword>
    </line>
    </sipLines>
    <dialTemplate>dialplan.xml</dialTemplate>
    </sipProfile>
    <userLocale>
    <name>English_United_Knigdom</name>
    <langCode>en</langCode>
    </userLocale>
    <networkLocale>United_Knigdon</networkLocale>
    <networkLocaleInfo>
    <name>United_Knigdom</name>
    </networkLocaleInfo>
    <commonProfile>
    <phonePassword></phonePassword>
    </commonProfile>
    <directoryURL></directoryURL>
    <servicesURL></servicesURL>
    </device>
  2. miro
    Jan 17, 2012
    51
    when you lift your handset on phone is there any change on phone display (enter number), can you even enter the number,if you can what happen when you press dial ? Did you check your cable on headset :)
    PS.
    We also have 7941, 7911, 7912 they all work like a charm .
    Best regards
