Cisco 7941 Provisioning
Discussion in '3CX Phone System - General' started by BA7389, Sep 9, 2011.
  1. BA7389
    Nov 20, 2010
    23
    There are many posts dating back several years on this subject, but...Can someone confirm latest working firmware versions, provide names of files that need to be present on TFTP server, and provide names and examples of the default and SEPMAC .xml files that allow this phone to connect to 3CX? If there are reasonably current posts covering this topic, my apologies.
    Thanks,
    Bruce
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    This phone should be able to be provisioned by 3CX automatically, please see below URL:
    http://www.3cx.com/sip-phones/linksys-SPA-962.html
  3. BA7389
    Nov 20, 2010
    23
    Assume you're saying that a Linksys SPA941 is the same as a Cisco 7941?
    Thanks,
    Bruce
  4. davidbenwell
    Apr 27, 2010
    704
    yes my mistake sorry,
    the 7940 needs to be configued via TFTP Server like the 7940.
    Take a look at http://www.3cx.com/sip-phones/cisco-7940g-7960g/
  5. Fatman2142
    Aug 11, 2013
    Hi Guys,
    I'm having issues provisioning my 7941.
    Would it be possible to get your config files from the TFTP? I've spent about a 4 weeks trying to get this to work and pretty much at the breaking point!
    Thanks,
    Hayden
