Cisco 7941
Discussion in '3CX Phone System - General' started by comprac, May 31, 2014.
  1. comprac
    May 21, 2014
    5
    Hello
    I am trying to use 3cx free to demo moving Cisco handsets to 3cx.
    One feature they need is blind call forwarding.
    Is it possible to do blind call forwarding on a using Cisco 7941 handset without dial codes.
    Andrew
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    You could do this through 3CXPhone for Windows / Mac or by setting up a blf key to change profile status and then have profile set to forward already...I know you need a paid for edition to set blf keys.
    Could also be done through vm prompts.
  3. comprac
    May 21, 2014
    5
    Thank you.. Some things in life customers just have to pay for..
