Cisco 7960 firmware upgrade
Discussion in '3CX Phone System - General' started by msp, Jul 12, 2009.
  1. msp
    msp
    Apr 23, 2009
    19
    Good day.
    I am have a time out issue when upgrading a Cisco 7960 phone to SIP firmware.
    It will load OS79XX.txt OK.
    In first attempt to convert the phone From SCCY (P003H310) to SIP firmware P03-03-00.It will only loads 94% of the firmware build and the Solarwinds TFTP server logs reports "timeout error: the connection is reset by remote side"
    Does anyone know how to over come this issue.
    Regards kelvin
  2. sipero123
    Nov 24, 2008
    94
    I found the easiet way to do this was with a locally sited pc. I set a static IP address for the pc and used tftpd32 as this has a built in dhcp server as well.
    I then accessed the Cisco 7960 phone and set the tftp server to the static IP of the PC.
    Please search on this forum as I did post a more detailed explanation several months ago with links for the software and fuller instructions.
    Jonathan Hamon
  3. msp
    msp
    Apr 23, 2009
    19
    I will give it a go and report back whether it has been successful of not.
    Thanks you for answering my issue in upgrading 7960 phone Jonathan.
    Regards kelvin
  4. msp
    msp
    Apr 23, 2009
    19
    I Tried the local PC with a static IP address, But, it still does not load the SIP software file.
    In the TFTP server logs it now reports "interrupted by client, received error packet with code 3" What does the mean.
    If I look at the firmware install on the 7960 phone it shows P003H310 App's load with boot load ID PC030310
    Can any one help.
    regards kelvin
  5. Discovery Technology
    Apr 19, 2008
    278
    What TFTP Server are you using? I have used the 3Com free TFTP Server with no problems with Cisco handsets.
    Also, do you have the latest firmware for the handsets? If you have SmartNet maintenance (which costs less than $10) this would be relatively quick to check.
