Cisco 7960 ( Stop Ip Displaying )
Discussion in '3CX Phone System - General' started by alex22alex, Jul 9, 2012.
  1. alex22alex
    Jun 11, 2008
    38
    Hi All,
    Any idea how you stop the server ip appearing after the callernumb on the cisco 7960. It does not seem to be possible from the phone itself is it possible to stop it in 3cx ?
    Thanks. Alex
    [​IMG]
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,566
    302
    Maybe in the trunk inbound did setup ?
  3. alex22alex
    Jun 11, 2008
    38
    Thanks for the suggestion i tried removing. The 'DevHostPort' from the inbound paramaters but this did not seem to do anything.
