Cisco 7960
Discussion in 'Windows' started by max@zl2max.gen.nz, Mar 5, 2011.
  1. max@zl2max.gen.nz
    Mar 3, 2011
    Hi Guys
    one of my Ciscos 7960, dosn't work, can't get anything from the key pad...
    Stick it on its own subnet on its own and you can ping it, but not telnet ...
    Is there some sort of master reset I can use to default it ??
    Max
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    There is often a factory reset for cisco but from a dial code or the phone interface, which may not help in your case.
    I cant help you as we avoid these phones (we enjoy the easy life :) )
  3. Sha1a
    May 18, 2011
    15
    Try pressing..
    * 6 and the settings button at the same time until Headset button lights up, release and press #. It will then display "re-set key sequence detected" when you see this press in order 123456789*0#. It will then ask if you would like to keep settings. Choose 2-No. Will then re-set to shipped defaults and firmware.
    Hope this helps.
  4. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    solution to your problem
    Install TFTP Server and reload the firmware & the configuration files.
    we had the same issue on a 7940 and this did the trick.
