Cisco 7961 Freezing after Transfer (All Devices, V14)
Discussion in '3CX Phone System - General' started by CSO_Trapeze, Sep 24, 2015.
  1. CSO_Trapeze
    Jan 20, 2015
    Since upgrading to V14, attended transfers cause the "transferer's" phone to hang after the transfer. Flow:
    Behavior: A Calls B, B answers, presses transfer, dials, C. C Answers, B presses transfer. A is connected to C, but A is still on hold on B's phone. B has to then reselect the line they just transferred (push the BLF button) and then end the call.
    Expected Behavior: After B transfers the call, the call should drop from B's phone.
    All phones are on 3cx recommended firmware. Softphones, and Polycom conference phones transfer fine.
    I have changed re-invite header, replaces header, and tried PBX delivers audio, no joy. We are going to get some new phones for the first responders, but would rather not have to replace the other 80 phones. The other option is rolling back to V13.
    Logs (verbose enabled):
    25-Sep-2015 07:48:47.933 Leg L:5.3[Extn] is terminated: Cause: BYE from PBX
    25-Sep-2015 07:48:47.932 [CM503008]: Call(C:5): Call is terminated
    25-Sep-2015 07:48:47.931 Leg L:5.1[Extn] is terminated: Cause: BYE from 172.27.84.44:49414
    25-Sep-2015 07:48:39.964 Leg L:5.2[Extn] is terminated: Cause: BYE from 172.27.84.53:49509
    25-Sep-2015 07:48:34.115 NAT/ALG check:L:5.2[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    SIP contact header is not equal to the SIP packet source(IP:port):
    Contact address:172.27.84.53:5060
    Received from :172.27.84.53:49509
    25-Sep-2015 07:48:26.006 Currently active calls - 1: [5]
    25-Sep-2015 07:48:15.347 Leg L:6.1[Extn] is terminated: Cause: BYE from PBX
    25-Sep-2015 07:48:15.346 [CM503008]: Call(C:6): Call is terminated
    25-Sep-2015 07:48:15.343 Leg L:6.4[Extn] is terminated: Cause: BYE from 172.27.84.5:49206
    25-Sep-2015 07:48:15.071 NAT/ALG check:L:5.1[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    Contact address:172.27.84.44:5060
    Received from :172.27.84.44:49414
    25-Sep-2015 07:48:14.830 [CM503007]: Call(C:5): Extn:711 has joined, contact <sip:711@172.27.84.5:5060>
    25-Sep-2015 07:48:14.825 L:5.3[Extn] has joined to L:5.1[Extn]
    25-Sep-2015 07:48:14.825 NAT/ALG check:L:5.3[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    Contact address:172.27.84.5:5060
    Received from :172.27.84.5:49206
    25-Sep-2015 07:48:14.625 [CM503025]: Call(C:5): Calling T:Extn:711@[Dev:sip:711@172.27.84.5:5060;transport=udp] for L:5.1[Extn]
    25-Sep-2015 07:48:14.417 NAT/ALG check:L:6.4[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:48:14.232 NAT/ALG check:L:6.1[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:48:06.771 Leg L:6.3[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    25-Sep-2015 07:48:06.769 [CM503003]: Call(C:6): Call to <sip:711@172.27.3.3:5060> has failed; Cause: 487 Request Terminated/INVITE from 127.0.0.1:5488
    25-Sep-2015 07:48:06.707 Leg L:6.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 172.27.86.32:8219
    25-Sep-2015 07:48:06.705 [CM503003]: Call(C:6): Call to <sip:711@172.27.3.3:5060> has failed; Cause: 487 Request Terminated/INVITE from 172.27.86.32:8219
    25-Sep-2015 07:48:06.570 [CM503007]: Call(C:6): Extn:711 has joined, contact <sip:711@172.27.84.5:5060>
    25-Sep-2015 07:48:06.568 [CM503007]: Call(C:6): Extn:713 has joined, contact <sip:713@172.27.84.53:5060>
    25-Sep-2015 07:48:06.566 L:6.4[Extn] has joined to L:6.1[Extn]
    25-Sep-2015 07:48:06.566 NAT/ALG check:L:6.4[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:48:02.982 [CM503025]: Call(C:6): Calling T:Extn:711@[Dev:sip:711@172.27.86.32:8219;rinstance=0-3720f3e13e854c0190fed810ed004df6;ob,Dev:sip:711@127.0.0.1:5488;rinstance=76ef1e297cb3db59,Dev:sip:711@172.27.84.5:5060;transport=udp] for L:6.1[Extn]
    25-Sep-2015 07:48:02.978 [CM503025]: Call(C:6): Calling T:Extn:711@[Dev:sip:711@172.27.86.32:8219;rinstance=0-3720f3e13e854c0190fed810ed004df6;ob,Dev:sip:711@127.0.0.1:5488;rinstance=76ef1e297cb3db59,Dev:sip:711@172.27.84.5:5060;transport=udp] for L:6.1[Extn]
    25-Sep-2015 07:48:02.973 [CM503025]: Call(C:6): Calling T:Extn:711@[Dev:sip:711@172.27.86.32:8219;rinstance=0-3720f3e13e854c0190fed810ed004df6;ob,Dev:sip:711@127.0.0.1:5488;rinstance=76ef1e297cb3db59,Dev:sip:711@172.27.84.5:5060;transport=udp] for L:6.1[Extn]
    25-Sep-2015 07:48:02.925 [CM503027]: Call(C:6): From: Extn:713 ("Ryan X" <sip:713@172.27.3.3:5060>) to T:Extn:711@[Dev:sip:711@172.27.86.32:8219;rinstance=0-3720f3e13e854c0190fed810ed004df6;ob,Dev:sip:711@127.0.0.1:5488;rinstance=76ef1e297cb3db59,Dev:sip:711@172.27.84.5:5060;transport=udp]
    25-Sep-2015 07:48:02.925 [CM503004]: Call(C:6): Route 1: from L:6.1[Extn] to T:Extn:711@[Dev:sip:711@172.27.86.32:8219;rinstance=0-3720f3e13e854c0190fed810ed004df6;ob,Dev:sip:711@127.0.0.1:5488;rinstance=76ef1e297cb3db59,Dev:sip:711@172.27.84.5:5060;transport=udp]
    25-Sep-2015 07:48:02.923 [CM503001]: Call(C:6): Incoming call from Extn:713 to <sip:711@172.27.3.3:5060>
    25-Sep-2015 07:48:02.923 NAT/ALG check:L:6.1[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:47:59.461 NAT/ALG check:L:5.1[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:47:59.353 NAT/ALG check:L:5.2[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:47:56.658 [MS211000] C:5.2: 172.27.84.53:30062 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
    25-Sep-2015 07:47:55.970 Currently active calls - 1: [5]
    25-Sep-2015 07:47:54.007 [CM503007]: Call(C:5): Extn:713 has joined, contact <sip:713@172.27.84.53:5060>
    25-Sep-2015 07:47:54.006 [CM503007]: Call(C:5): Extn:714 has joined, contact <sip:714@172.27.84.44:5060>
    25-Sep-2015 07:47:54.005 L:5.2[Extn] has joined to L:5.1[Extn]
    25-Sep-2015 07:47:54.003 NAT/ALG check:L:5.2[Extn] RESPONSE 200 on 'INVITE' - some of SIP/SDP headers contain inconsistent information or modified by intermediate hop
    25-Sep-2015 07:47:50.750 [CM503025]: Call(C:5): Calling T:Extn:713@[Dev:sip:713@172.27.84.53:5060;transport=udp] for L:5.1[Extn]
    25-Sep-2015 07:47:50.700 [CM503027]: Call(C:5): From: Extn:714 ("Steven X" <sip:714@172.27.3.3:5060>) to T:Extn:713@[Dev:sip:713@172.27.84.53:5060;transport=udp]
    25-Sep-2015 07:47:50.700 [CM503004]: Call(C:5): Route 1: from L:5.1[Extn] to T:Extn:713@[Dev:sip:713@172.27.84.53:5060;transport=udp]
    25-Sep-2015 07:47:50.697 [CM503001]: Call(C:5): Incoming call from Extn:714 to <sip:713@172.27.3.3:5060>
    25-Sep-2015 07:47:50.697 NAT/ALG check:L:5.1[Extn] REQUEST 'INVITE' - some of SIP/SDP headers may contain inconsistent information or modified by intermediate hop
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Please upgrade your phone system to latest service pack if that's not already the case and ensure that all cisco phone templates are up-to-date through the Updates node, as there have been some changes on the cisco 79x templates related to transfer issues. Then edit your extension, don't make any change, just validate. Finally, reset and reprovision your phone so that it takes its new configuration file and let us know of the outcome.
