Cisco 7970 ip phone conference call
Discussion in '3CX Phone System - General' started by evosoft, Jun 3, 2015.
  1. evosoft
    Jul 18, 2014
    I have cisco 7970 ip phones working ok with 3cx. But when i try to complete a conference call i can't merge the 2 calls pressing the conference key. It just come up with error on the phone screen that it could not be completed.
    Please advice on this issue.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Cisco 7970 are not supported by 3cx as per list of supported devices on http://www.3cx.com/support
    For conferencing functionnality to work correctly you will need to use a supported device with provisioning template.
  3. Jamie Bennett
    Dec 18, 2016
    12
    When will the 7970's, the 7965's and the 7975's be supported? Those are great phones that are more modern than the 7960's.
