Cisco 7970 IP Phone on 3CX?
Discussion in '3CX Phone System - General' started by Lee Moreau, Jul 23, 2012.
  1. Lee Moreau
    Jul 23, 2012
    27
    Anyone have any idea how to make this work? I've flashed it to SIP but having issues. Seems like this phone is really tricky even with Asterisk but from what I can tell, on Asterisk only certain firmwares seem to work on it. I tried with 8-5-4S which seemed to have the best luck. It would show in 3CX that it was registered and if I called it it would receive a call (but not be able to answer it) but the phone would just say Registering forever or show an X over the line.
    I upgraded to 9.0.3S or something like that but now it doesn't even register at all. There's so many firmware versions and it's a major pain to keep changing them around so was wondering if anyone had any experience getting this to work?
    10,773
    286
    If you do a search of the forum you will come across a number of posts on that model...like this one
    http://www.3cx.com/forums/cisco-7970-and-3cx-it-works-1152-15.html
  3. Lee Moreau
    Jul 23, 2012
    27
    Thanks so much! I feel so dumb I was literally searching all morning and didn't find that post, but I got it working woohoo.
