Cisco 7975G configuration
Discussion in 'Windows' started by ndalikan, Jun 2, 2011.
  1. ndalikan
    Jun 2, 2011
    I have obtained the attached from Cisco support but as they do not provide support for 3CX, they referred me to 3CX support who then referred me here....
    I am trying to configure this phone to work with 3CX. So far, I have managed to connect the phone to the 3CX (it appears as registered in the 3CX consol) and I am able to make the phone ring, when dialing its extention.
    And that's about it.
    I am unable to answer the call, to make a call or use the other features of the phone.
    Is there a way to have your support on this?
    Thank you in advance,
    Nikos
  2. jleed
    Dec 22, 2011
    14
    THE SAME! help some one.
  3. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Hello I actually have a 7975 and was about to attempt to configure for use with my 3cx I just havent had a chance to get to it. I recently asked the same question and was directed to this link. It should be of some help to you, though I hear its extremely irritating at sometimes. the second link is the step by step procedures with all the needed config files hope this helps!!!
    http://www.3cx.com/forums/cisco-24242.html
    http://www.888voip.com/configuring-cisco-7975-ip-phones-for-sip/
