Cisco 79xx line key provision difficulty (LN, SPx, SD,etc.)
Discussion in '3CX Phone System - General' started by sprengd, Jun 10, 2014.
  1. sprengd
    Jun 10, 2014
    System: v12 trial license
    Phones: Cisco IP 7940 & Cisco IP 7960
    Using management console I have assigned BLFs starting at line 3: BLF, SP0, SP1, SP2 on specific 7960 phone. I have verified that the system has saved the configuration because I can come back to the phone provision screen for this phone and line(x) assignments are configured. However, the SIPxxxxxxxxx.cnf file in the provision Data folder does not have the custom assignments for the keys. The cnf file for this phone still has the DEFAULT assignments for all Lines 1-6.
    I've checked to see if there are further template updates for the Cisco 79xx series phones from the management console systems updates.
    What am I missing in the provision process?
    Thanks for any help given.
    -DjS
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Re: Cisco 79xx line key provision difficulty (LN, SPx, SD,et
    Hi there,
    No BLF can be set for these specific phones, if you look in the template aswell there is no blf related sections.
