paddi
- Joined
- Apr 22, 2016
- Messages
- 4
- Reaction score
- 0
Hi All,
was looking for some pointers as to where i might be going wrong , i have set up NAT and firewall as per the instructions on the site on our cisco router but im still seem to be having problems when running the firewall checker and have no idea where im going wrong , as i have think i have the config correct
i've pasted in some of the results and port 5060 seems to connect but the other drop ???
any ideas ?
Testing SIP Port 5060 using STUN server: stun.3cx.com:3478
Resolving STUN server stun.3cx.com ... Resolved to: [198.50.247.220]
[Test1] Reachability test ... Resolved Public IP: 80.194.146.251:5060
STUN server stun.3cx.com has second address 198.50.247.219:3479
[Test2] One on One Port Forwarding ... OK.
Testing Tunnel Port 5090 using STUN server: stun.3cx.com:3478
[Test1] Reachability test ... Resolved Public IP: 80.194.146.251:5090
[Test2] One on One Port Forwarding ... FAILED.
No response received or port mapping is closed. Firewall check failed. This configuration is not supported
Testing External Audio RTP Port 9000 using STUN server: stun.3cx.com:3478
[Test1] Reachability test ... FAILED.
Internal port number (9000) does not match external port number (9499)
Testing External Audio RTP Port 9001 using STUN server: stun.3cx.com:3478
[Test1] Reachability test ... Resolved Public IP: 80.194.146.250:9001
any ideas ?
