Cisco Handset Compatibility
Discussion in '3CX Phone System - General' started by DaveShawAD, Jun 18, 2013.
  1. DaveShawAD
    Jun 18, 2013
    Please can somebody tell me if our existing handsets would be compatible with a 3CX IP PBX?
    Currently we have:
    CISCO IP PHONE 7940 SERIES
    CISCO IP PHONE 7960 SERIES
    CISCO IP PHONE 7912 SERIES
    11,291
    361
    Cisco can have a SIP firmware load, or not. If it is SIP, then there is a good chance it will work. Some are easier to configure than others. Do a search of the forum using the specific model numbers (one at a time).
  3. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,777
    280
    @DaveShawAD
    You first have to get the SIP firmware for the phones. For the 7940 and 7960 this should be readily available. For the 7941 and 7961 you will need a Cisco support contract to get it. Once you've flashed the phones over to SIP firmware, you can follow these instructions:
    http://www.3cx.com/sip-phones/cisco-7940g-7960g/
    Also, you may want to try the v12 alpha and take a look at the phone templates.
