Cisco IP Communicator
Discussion in '3CX Phone System - General' started by Tularis, Apr 28, 2010.
  1. Tularis
    Apr 12, 2010
    16
    Does 3CX Support the Cisco IP Communicator, I can only seen Cisco SPA phones in the provision list and a quick google search doesnt reveal anything.
    By default the Cisco IP Communicator is set to SCCP but it can be configured to SIP tho I'm not sure how to achieve this with out Cisco CM.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
  3. Tularis
    Apr 12, 2010
    16
    Hmmm thats a shame,
    I did figure out how to put it into SIP mode tho.
    Code:
    msiexec /i CiscoIPCommunicatorSetup.msi /qb SIP=1
    Does 3cx Support Generic SIP phones? Possibly so that a generifc cnf file can be created for the Phone?
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Generic templates are not available as templates are model specific, you could try and set it up manually and see how you go form there. Maybe a Cisco manual configuration guide might help you achieve this.
    http://www.3cx.com/sip-phones/ Updated link
    Again this is not a supported device and i strongly recommend you try the 3CX VOIP phone.
