Cisco IP Phone CP-8941 and 3CX for Windows
Discussion in 'Windows' started by eurois, Feb 18, 2016.
  1. eurois
    Feb 18, 2016
    I am doing some test on a 3CX System for Windows and I want to know if the IP PHone from CISCO CP-8941 is supported?
    And if it is supported if there is a procedure to be able to use it with 3CX for Windows.
    Thanks in advance for your help and your reply ;)
    10,587
    253
    If there is no template for auto configuration, then it's not (officially) supported. This doesn't necessarily mean it won't work, just that , at this point, you are an you own. Cisco sets are notorious for making things difficult when trying to use them with anything other than a Cisco system. Do some internet searches, on "standard" SIP compatibility, before spending a lot of time trying to get it to work.
