Cisco Phone 7911G cannot make a call
Discussion in 'Windows' started by asia2, Aug 12, 2011.
  1. asia2
    Oct 12, 2010
    Hi Guys,
    Anyone can help me on Cisco Phone 7911G. I Upgrade the firmware from SCCP to SIP then I Upload it in tftp then I edit the SEP0024142DA507.cnf.xml, then theres an error:
    Connection received from 10.13.60.51 on port 49152 [12/08 11:05:48.875]
    Read request for file <CTLSEP0024142DA507.tlv>. Mode octet [12/08 11:05:48.875]
    File <CTLSEP0024142DA507.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [12/08 11:05:48.875]
    Connection received from 10.13.60.51 on port 49153 [12/08 11:05:48.985]
    Read request for file <SEP0024142DA507.cnf.xml>. Mode octet [12/08 11:05:48.985]
    Using local port 1581 [12/08 11:05:48.985]
    <SEP0024142DA507.cnf.xml>: sent 14 blks, 6924 bytes in 1 s. 0 blk resent [12/08 11:05:49.000]
    Connection received from 10.13.60.51 on port 49154 [12/08 11:05:55.797]
    Read request for file <SIP11.8-3-15.loads>. Mode octet [12/08 11:05:55.813]
    File <SIP11.8-3-15.loads> : error 2 in system call CreateFile The system cannot find the file specified. [12/08 11:05:55.813]
    Connection received from 10.13.60.51 on port 49155 [12/08 11:06:13.172]
    Read request for file <CTLSEP0024142DA507.tlv>. Mode octet [12/08 11:06:13.172]
    File <CTLSEP0024142DA507.tlv> : error 2 in system call CreateFile The system cannot find the file specified. [12/08 11:06:13.172]
    Read request for file </tc-sip.jar>. Mode octet [12/08 11:06:17.922]
    File <\tc-sip.jar> : error 2 in system call CreateFile The system cannot find the file specified. [12/08 11:06:17.922]
    Connection received from 10.13.60.51 on port 49158 [12/08 11:06:19.094]
    Read request for file <United_States/g3-tones.xml>. Mode octet [12/08 11:06:19.110]
    File <United_States\g3-tones.xml> : error 3 in system call CreateFile The system cannot find the path specified. [12/08 11:06:19.110]
    Connection received from 10.13.60.51 on port 49160 [12/08 11:06:19.844]
    Read request for file <dialplan.xml>. Mode octet [12/08 11:06:19.844]
    File <dialplan.xml> : error 2 in system call CreateFile The system cannot find the file specified. [12/08 11:06:19.844]
    And I try to use the Cisco phone to call ext 6000 but it eliminate the last 3 digits. it on shows on LCD panel.
    Please anyone help me on this concern..
    JV
