- Joined
- Apr 7, 2007
- Messages
- 121
- Reaction score
- 0
3CX Phone System Version 3.1.2434.0
Cisco 2811 Router with ISDN PRI
Cisco 7941 Phones
I have not been able to successfully complete transfers with Cisco phones and 3CX. In the scenario displayed in the packet capture below I have received an incoming call from 9072223333 on an ISDN PRI line (10.1.3.13) and it is answered by 2224444. 2224444 (extension 4444) transfers the call to extension 4419. Outside caller begins to hear music on hold. 4419 answers call but now also hears the music on hold. Message on 4444 indicates “cannot complete transfer”. And complete transfer never occurs. I have tried every available setting on the advanced options for the ISDN gateway.
I have tried Alpha 4 and do not get the 3CX error below and occasionally do get successful transfers, but most times not.
In the 3CX Log below I do not understand why the To: is 907222333 when that is the outside caller number and the call is being transferred to 4419.
I would appreciate any help someone could provide.
3CX LOG:
[CM010001] Line configuration does not allow identification of the source of this call. Check Advanced Options for Gateways and Providers and match a field to a correct value from the following: Contact IP: '10.1.3.7'; From: '2224444'; To: '9072223333'; Rline: '9072223333'; Contact: '2224444'
PACKET CAPTURE: two packets
No. Time Source Destination Protocol Info
1718 12.550655 10.1.3.7 10.1.3.3 SIP Request: REFER sip:[email protected]:5060
Frame 1718 (746 bytes on wire, 746 bytes captured)
Ethernet II, Src: Cisco_52:c7:58 (00:1b:54:52:c7:58), Dst: Intel_b4:ff:de (00:02:b3:b4:ff:de)
Internet Protocol, Src: 10.1.3.7 (10.1.3.7), Dst: 10.1.3.3 (10.1.3.3)
User Datagram Protocol, Src Port: 49236 (49236), Dst Port: 5060 (5060)
Session Initiation Protocol
Request-Line: REFER sip:[email protected]:5060 SIP/2.0
Method: REFER
[Resent Packet: False]
Message Header
Via: SIP/2.0/UDP 10.1.3.7:5060;branch=z9hG4bK05d29bcd
Transport: UDP
Sent-by Address: 10.1.3.7
Sent-by port: 5060
Branch: z9hG4bK05d29bcd
From: "2224444"<sip:[email protected]:5060;transport=udp>;tag=001b5452c758001076fc022d-dc7a813d
SIP Display info: "2224444"
SIP from address: sip:[email protected]:5060
SIP tag: 001b5452c758001076fc022d-dc7a813d
To: "9072223333"<sip:[email protected]>;tag=f2708061
SIP Display info: "9072223333"
SIP to address: sip:[email protected]
SIP tag: f2708061
Call-ID: ZWNhNjFhMWU2NmJlZThlNmIyZjAyNDE5NWE3NGUwMDM.
Max-Forwards: 70
Date: Sat, 17 Nov 2007 05:46:36 GMT
CSeq: 102 REFER
Sequence Number: 102
Method: REFER
User-Agent: Cisco-CP7941G/8.3.0
Contact: <sip:[email protected]:5060;transport=udp>
Contact Binding: <sip:[email protected]:5060;transport=udp>
Refer-To: <sip:[email protected];user=phone?Replaces=001b5452-c758000a-d256ef17-fac412f1%4010.1.3.7%3Bto-tag%3D3c1fcf3f%3Bfrom-tag%3D001b5452c7580011c82b31db-4657bec5>
Referred-By: <sip:[email protected]>
Content-Length: 0
1739 12.752382 10.1.3.3 10.1.3.7 SIP Status: 404 User Not Found
Frame 1739 (407 bytes on wire, 407 bytes captured)
Ethernet II, Src: Intel_b4:ff:de (00:02:b3:b4:ff:de), Dst: Cisco_52:c7:58 (00:1b:54:52:c7:58)
Internet Protocol, Src: 10.1.3.3 (10.1.3.3), Dst: 10.1.3.7 (10.1.3.7)
User Datagram Protocol, Src Port: 5060 (5060), Dst Port: 5060 (5060)
Status-Line: SIP/2.0 404 User Not Found
Status-Code: 404
Message Header
Transport: UDP
Sent-by port: 5060
SIP tag: f2708061
CSeq: 102 REFER
Method: REFER
User-Agent: 3CXPhoneSystem
Content-Length: 0
Cisco 7941 Phones
3CX LOG:
Method: REFER
Message Header
Transport: UDP
Sent-by port: 5060
SIP tag: f2708061
Max-Forwards: 70
CSeq: 102 REFER
Method: REFER
Content-Length: 0
Status-Code: 404
Message Header
Transport: UDP
Sent-by port: 5060
SIP tag: f2708061
CSeq: 102 REFER
Method: REFER
Content-Length: 0
