Cisco SPA 112
Regis_Technologies_USA
Anyone have any luck configuring a Cisco SPA 112 to 3cx? Got device to register but not able to receive calls and also not showing as a phone on 3cx... Help pls
As a regular extension or as an ATA?
as a regular remote extension
Well I was going to say that I think if you register it as an fax ATA it shows up under system extension but a regular extension should show up under phones. The only think that makes sense is it's not registered to the PBX. Why do you think it is registered?
I know it is registered to the pbx because I am able to make out going calls. When i call a phone it is showing the caller Id as the stun url... I am not able to receive calls though through the ext and sip DID number
I would recommend using one of the supported devices listed here: https://www.3cx.com/voip-gateways/
Supported devices can be provisioned through the PBX saving you the hassle of trying to manually register the device and having to manually configure each setting.
Thank you YiannisH_3cx. Do you know if the Grandstream HT802 can you be used in remote (STUN).?
Please note that all gateways are only supported for local provisioning and use. To use a gateway when the PBX is in the cloud the supported method is a VPN connection to the remote site.
oh okay thank you for your help!
Getting Started - Admin
Ghisl1
Get 3CX - Absolutely Free!
3CX
