Cisco SPA 504 time format
Discussion in 'Windows' started by mixig, May 14, 2013.
  1. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    by default it has 12h time format, i need 24h time format, i found on the web interface where to change that but in the provisioning template i can`t find that part of the configuration, when i changed on web interface and to reprovisiong it still stay 24h format which i changed on the web, with that i think there is no configuration for time format in the template. Where can i add that part in the config file/template?
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Add this to your template.
    Code:
    <Time_Format>24hr</Time_Format>
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Can I put that code anywhere or under the specific section?
  4. ian.watts
    Apr 8, 2011
    532
    The Cisco XML model is pretty flat.. there may be a "pretty" place to put it but in the end it shouldn't matter a whole lot.
