cisco spa 7.4.7 new firmware
Discussion in '3CX Phone System - General' started by equintana, Feb 14, 2011.
  1. equintana
    Dec 20, 2010
    57
    I must upgrade some of my phones from 7.4.6 to 7.4.7 to avoid some problems I have right now. As I can see t 3cx console, only 7.4.6 is supported.
    Could I upgrade?
    regards
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You could upgrade, it hasnt been tested or is supported but normally its previous version that dont work rather then newer versions.
  3. equintana
    Dec 20, 2010
    57
    There is a bug caused by the 7.4.6 firmware, fixed with this new one7.4.7.
    When will be supported by 3cx?
    Please is very urgent!!!!
