Cisco SPA Provisioning problem
Discussion in '3CX Phone System - General' started by diversified1, Jan 15, 2010.
  1. diversified1
    Nov 19, 2009
    5
    im not sure if anyone else is having this problem - but when i use the auto phone provisioning while creating an extension... the phone provisions correctly all but the BLF's
    all i get is the same extension on every line.
    Im using a brand new SPA 504g, tried both firmware 7.3.7 and 7.4.3.
    any ideas?
    domenick
  2. eug
    eug
    Mar 2, 2010
    36
    I have this same problem. Why don't the BLFs I select under Extensions -> 1xx -> Phone Provisioning -> BLF get configured on the phone automatically? I have selected the correct model under Provisioning.
    This happens with both v8 and v9 SP1.
  3. activeserve
    Jun 29, 2009
    25
  4. danoh
    Aug 18, 2010
    56
    I wish it would work like you want. It would save a LOT of hassle.
    For now, what I do is exit the provisioning template for the Cisco phone and at the bottom, before </flat-profile> you can add:
    <Extension_7_ group="Phone/Line_Key_7">Disabled</Extension_7_>
    <Short_Name_7_ group="Phone/Line_Key_7">Dan</Short_Name_7_>
    <Share_Call_Appearance_7_ group="Phone/Line_Key_7">private</Share_Call_Appearance_7_>
    <Extended_Function_7_ group="Phone/Line_Key_7">fnc=blf+sd;sub=1002@$PROXY;nme=1002</Extended_Function_7_>
    Where the 7's are the line key number on the phone.
    You can edit the provisioning template and add anything that the Cisco phones understand to it, for a totally customized provision.
    Like:
    <Default_Ring__1__ group="Ext_1/Call_Feature_Settings">5</Default_Ring__1__>
    <Default_Ring__2__ group="Ext_2/Call_Feature_Settings">5</Default_Ring__2__>
    <Default_Ring__3__ group="Ext_3/Call_Feature_Settings">5</Default_Ring__3__>
    <Default_Ring__4__ group="Ext_4/Call_Feature_Settings">5</Default_Ring__4__>
    Hope it works for you!
    -Dan
  5. casualmikey
    Jul 24, 2010
    21
    Hi, I'm just getting into this on the tail end. So based on what i've read, multiple extensions cannot be provisioned automatically? If we want to have more than one extension on a phone (more than one blf configured), we have to manually do it?
    I'm a new to this but just wanted confirmation before I go about the hassle of setting each and every phone up.
  6. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Had you asked me in V8 I would have said no - you cannot provision multiple extns on the blf - you do the main one and then add the others in the web interface for the phone.
    However you can adjust the templates if you want to.
    And I have just noticed in v9 that my 2nd extension on my SPA942 is now showing in the 3cx blf (but i did provision it manually on the phone) so maybe you can now.
  7. casualmikey
    Jul 24, 2010
    21
    I tried to provision the additional extension on the phone last week with v. 9 but it did some weird things. I first created a main extension for the phone, then created two other extensions and then assigned those extensions as BLF's in the main extension's BLF list. It was weird because the phone would sometimes provision one extension over another then when I reset the phone to factory, it would provision with another extension. Very erratic behavior. It was then I decided to make the other extensions non-provisioned.
    If it were to be provisioned, am I going about it the correct way? I'm using SPA-508G's.
