Cisco SPA122
Discussion in '3CX Phone System - General' started by mood66, May 29, 2014.
  1. mood66
    May 29, 2014
    I leave in Egypt , have cisco SPA122 & analog line everything in 3cx work fine in my place but when I connect my analog line it keep line open and I think I can't make good configuration for analog line connected with SPA122 can any one help in this what should I do in 3cx and also in sp122 to make any one call me in analog line ring in ip phones also any one in network can make calls via analog line
    10,360
    226
    If I understand you correctly, it sounds as if you are plugging an analogue phone line into one of the sockets of the SPA122 and it is seizing the line. Understandable, as that is not what it was designed for. The 122 is to connect two telephones to a VoIP PBX or provider, it replaced the SPA-2102. To bring an analogue (PSTN) phone line into 3CX (as a trunk) you require a PSTN gateway, such as the FXO port of an SPA-3102.
  3. mood66
    May 29, 2014
    Thanks Leejor
    I think you understand what I am talking about
    yes by mistake I buy SPA122 I should buy device with FXO , but after this with model SPA-2102 i can received all my traditional analog calls to 3CX and can talk this line through 3cx and make call via my ip phone
  4. leejor
    10,360
    226
    Do you mean...If i purchase a SPA-3102 i will be able to receive all of my traditional analogue calls.....
    Yes. The 3102 allows you to connect an analogue telephone line to 3CX as a trunk. From 3CX you can use the SPA-122 to connect two analogue phones (extensions) along with any number of VoIP phones. The SPA-3102 also has one FXS port to allow for an additional analogue telephone set (extension).
    The SPA-2102 is simply an older version of what you already have.
  5. mood66
    May 29, 2014
    great, thanks again for help and support and your time i buy
    Linksys SPA 3102 Voice Gateway Router VoIP
    http://www.ebay.com/itm/NEW-Unlocked-Linksys-SPA-3102-Voice-Gateway-Router-VoIP-/180880369608?pt=US_VoIP_Phone_Adapters&hash=item2a1d4f67c8
  6. leejor
    10,360
    226
    Read through this...
    http://www.3cx.com/voip-gateways/linksys-spa3102/
    It says that it is not supported (any longer), but it works, I use several. it also says that the use of the FXO and FXS port at the same time is not supported, but, it works. There are also some suggested settings that may not work for your region. If you have any problems with the configuration, come back to the forum and I'll help you with it.
    Get the FXO (PSTN) port working first, then, work on the FXS port.
