Cisco SPA302D
Discussion in '3CX Phone System - General' started by elytronic, Apr 10, 2013.
  1. elytronic
    Jun 15, 2012
    27
    Anybody have tried this with 3CX? Seems like an interesting choice for us but I am also very surprised that Cisco decided to release a DECT phone and not a Wifi one...
    http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10998/ps12776/data_sheet_c78-717757.html
    10,360
    226
    I would assume that they steered away from a Wifi interface because of the excessive battery drain that has plagued Wifi handsets in the past, along with the fact that with DECT, they maintain (quality) control from the Ethernet socket right to your ear.
    The price also seems to be less than Wifi handsets if you have more than one handset with one base unit. It also uses standard AA Nimh batteries. Base allows 11 sip accounts (Two per DECT handset) and one on the FXS port. Very interesting, I may have to spring for one.
  3. netswork
    netswork Active Member
    Mar 11, 2011
    577
    I just installed one at a Dr office. Easy to configure and seems to work well. Has a good range. The ringer does not get very loud if I had one complaint that would be it. I can't comment on battery life but the customer has not complained.
