Cisco SPA3102 Replacement
Discussion in '3CX Phone System - General' started by cdfosburg, May 6, 2015.
  1. cdfosburg
    May 6, 2015
    Seems the 3102 is hard to come by at a decent price. Also, it appears to be discontinued. I need two devices for faxing needs for 3CX version 12.
    Anyone know what device superceeds the 3102 and still works as well with 3CX?
    Thanks,
    Chris
    10,375
    231
    It depends on where you are located. I just had a look on Amazon.com, and there are still 3102's listed for sale. Prices do vary greatly depending on provider. There also appear to be some other 1 FXS/1 FXO devices, but I can't vouch for compatibility with 3CX. Some other forum member may be able to shed more light on that.
    Keep in mind that even the 3102 is no longer "officially " supported.
  3. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    check out http://shop.it-communicationsltd.co.uk/voip-gateways/cisco-spa122-analog-adapter-ata-with-router.html this will do the job. Can do two faxes with one box :)
  4. CentrexJ
    CentrexJ Member
    May 5, 2009
    391
    53
    I wouldn't purchase the SPA3102 it is a very old device and somewhat flaky. It has long been discontinued.
    These are the officially supported adapters: http://www.3cx.com/voip-gateways/
    Also works well with 3CX and formerly officially supported adapters still readily available are HT701, HT702 and HT704. SPA112 and SPA122. I have used all with 3CX at several customers for Faxing over T.38 voip trunks. Preference is on the HT models.
    The Wellgate 172Plus-POE looks pretty neat and is officially supported with 3CX. I like that it can be POE powered which simplifies wiring at customers with readily available POE outlets.
    http://www.3cx.com/voip-gateways/welltech-wellgate-ata172plus/
    Unfortunately for us our local suppliers don't sell the Wellgate and Beronet products (including the 3CX distributor for Canada). As such I have no experience with it but if 3CX recommends it, you can bet it is well tested.
  5. cdfosburg
    May 6, 2015
    We tried some of the Patton that were supported by 3CX and we had multiple issues, which is why we started to use the 3102 to connect to t.38 fax machines. They have been spot on based on the way they are setup, which ironically is documentation from 3CX.
    The SPA122 looks like a winner, ordered one from Amazon (We are in the US, but thank you for the link). Setup looks straight forward.
  6. cdfosburg
    May 6, 2015
    I did think of a question for those using the SPA122. Is there a specific firmware that you are sticking with, or would the most recent do?
    I know with 3102 3CX wanted 5.1.10 GW I think.
  7. leejor
    10,375
    231
    I had assumed that you were looking for a device with both an FXO and FXS port. The "older" device with two FXS ports was the SPA2102, and can still be found. It's replacement is the SPA122.
    I have used a number of the 3102s (still do),and have never had one fail, or had any issues with them. For a device with both FXS and FXO, they are extremely flexible, and offer features beyond most what most people will use. It is unfortunate that Cisco has not seen fit to come out with a direct replacement.
  8. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    I also have a number of 3102’s connected to different 3CX PBX’s all running with f/w 5.2.13 and, just like leejor, never had issues with them.
