Cisco SPA502G randomly reboots
Discussion in '3CX Phone System - General' started by tkirke, May 20, 2010.
  1. tkirke
    May 6, 2010
    5
    We are using Cisco SPA502Gs and have noticed that the phones occasionally reboot or go offline.
    Looking through the 3CX phone log, I can see that we get several re-registrations of random extensions through the day and night.
    We have also got the Cicsos running wirelessly using the Cisco Wireless-G Ethernet Bridge.
  2. bbusino
    Dec 4, 2009
    10
    We have a phone that does the exact same thing. I haven't had time to look into it but I wonder if its a defect or some provisioning thing. All phones were provisioned the exact same way though...
  3. tkirke
    May 6, 2010
    5
    All our phones were provisioned in the same way through 3CX. It is completely random wihch phone will do it and when. In some cases, we have a phone that can make outgoing calls, but can't receive calls. I assume that this is because the server has lost the registration.
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Kindly follow guidelines described in http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
    In case if PBX doesn't deliver (or cannot deliver) call to specific extension, PBX log contains description of reasons.
    About "reboot": PBX has no chance to reboot phone(except the case if you explicitly reboot it from management console). May it be the crash of phone software?
  5. tkirke
    May 6, 2010
    5
    I've reduced the registration interval on the phones to 300 seconds rather than the default 900 and this appears to have cured the problem - no re-registrations since yesterday lunchtime.
