Cisco SPA504G and Skype Gateway
Discussion in '3CX Phone System - General' started by acity, Oct 27, 2010.
  1. acity
    Oct 27, 2010
    I've setup the 3CX system (v9) using the skype gateway and I've had no problems using the softphone to make calls. I recently got two SPA504G phones to test and I can make calls to/from internal extensions with no problems.
    I can make external calls too and it works up to a point. If I have to press a keypad key, it does not behave as expected. Example - I call a local number and I'm greeted with a voicemail prompt "press 2 for sales". When I press the keypad "2" it beeps, but does not initiate the tone on the other end - nothing happens. I've pressed multiple buttons, even for extended time, yet it does not work. The soft phone works fine.
