Cisco SPA504g Provisioning Issues
Discussion in '3CX Phone System - General' started by jgibbons3, May 17, 2016.
  1. jgibbons3
    May 17, 2016
    14
    I am attempting a trial of 3CX and have installed version 14.3 on a Windows 7 Professional 64 bit machine. I have followed the steps for both DHCP option 66 provisioning as well as manual configuration and I can not get my phones provisioned. It appears there are some slight changes in the latest version that do not match up with the provisioning documentation for legacy phones.
    I have performed a factory reset to my phone and upgraded the firmware to 7.6.1 The Admin login is unlocked
    Any guidance or suggestions would be greatly appreciated.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
  3. jgibbons3
    May 17, 2016
    14
    I have tried that (http://FQDN:pORT/provisioning/PROVSUBDIR/$MA.xml) along with using the specific macaddress.xml that someone suggested in a previous post that I saw. I have also verified that my FQDN is resolving internally correctly, and I have tried using the IP address instead of FQDN.
  4. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Did you replace PROVSUBDIR by the actual provisioning random subdirectory? if not please do so, the sample URL can be seen in System status, bullet 5.
    Also the $MA must remain as $MA, it gets dynamically replaced by phone.
  5. jgibbons3
    May 17, 2016
    14
    ok, when I changed to http I didn't get the correct port -- thanks for the help.
    I am able to receive incoming calls, however when I attempt to dial outgoing calls I get either an invalid number or temporarily unavailable message. Any ideas?
    thanks again for the help.
  6. jgibbons3
    May 17, 2016
    14
    the error msg within the event log is:
    "Call or Registration to 93839961@(Ln.10000@Vitelity) has failed. [ V4 64.2.142.87:5060 UDP target domain=unspecified mFlowKey=984 ] replied: 484 Address Incomplete; from IP:64.2.142.87:5060"
    Any ideas?
  7. leejor
    10,742
    281
    OK, perhaps, one of two things...93839961, is not a "complete number", or, (Ln.10000@Vitelity), requires a "dot something" after Vitality in your trunk provider data fill.
  8. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,338
    76
    I agree, but start simple, can you call other extensions?
