Cisco SPA504G Registration Provisioning issues
Discussion in '3CX Phone System - General' started by grnerd, May 15, 2015.
  1. grnerd
    Aug 6, 2014
    22
    I have acquired a single SPA504G to test with our 3CX system. Our 3CX system is offsite, I use Option 66 for provisioning.
    I reset the phone to factory defaults, and updated the firmware to 7.5.7s. Our 3CX is v12.0.41311.996 SP.6.2.
    I created a new extension and added the MAC and chose Cisco SPA-504G as the model. Then I connected the phone to our network. It receives a DHCP address from our server, but never reaches the 3CX server to register or provision. Nothing in the server logs to indicate if it ever made it there.
    I then followed the instructions from this article http://www.3cx.com/sip-phones/cisco-spa/ and updated the profile rule using the admin interface on the phone. Still not connecting.
    I will try to roll back the firmware on the phone this afternoon to see if that has any effect, but I was wondering if any of you might have insight into something else I might have missed.
  2. grnerd
    Aug 6, 2014
    22
    Rolled back to 7.5.5
    No luck provisioning with just that change.
    Logged into the phone web interface, and changed the provisioning profile rule from http://x.x.x.x:5000/provisioning/blahblah/$MA.xml to
    http://x.x.x.x:5000/provisioning/blahblah/{actual mac address}.xml
    Phone connected and provisioned.
    Now there are no lines registered. One step at a time...
