Cisco SPA504g with Sidecar, Call transfer
Discussion in 'Windows' started by onboard, Jul 25, 2011.
  1. onboard
    Jan 12, 2011
    Hi There,
    Have 3CX setup using Cisco SPA504g and sidecar, If I answer an incomming call and want to transfer to another extension using xfer option (announced transfer) and select the extension from the sidecar the incomming call is put on hold and a second line is connected to the extension I have dialed. I an then unable to connect the incomming call to the dialed extension.
    Is there a reason for this and can it be fixed.
    If I use the bxfer option the call is passed directly !
  2. ip19
    Feb 7, 2011
    15
    what cisco firmware version are you running? the behavior of the transfer with the sidecar change extremly from 7.4.3 (not officilally supported by 3cx) to 7.4.6 (default requested firmware version) and a little bit to 7.4.7 and 7.4.8 (also not officially supported by 3cx)
  3. onboard
    Jan 12, 2011
    Hi ,
    the firmware version is 7.4.6
  4. ip19
    Feb 7, 2011
    15
    ok, with 7.4.6 we usually say:
    blind transfer: while talking push the sidecar internal extension button
    announced transfer: while talking push the HAND button (put in hold), push the sidecar internal extension and
    a) if the other side accept the call, push XFER button
    b) if the other side don't wont the call or it's not responding, push the blinking line button.
    Bye
    Ale
