Cisco SPA504G
Discussion in '3CX Phone System - General' started by BigRich171, Feb 9, 2017.
  1. BigRich171
    Jan 4, 2017
    9
    Is there a way to remove the above phones from the console as the extension is now being used as a softphone via the software?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,326
    532
  3. BigRich171
    Jan 4, 2017
    9
    On the 3cx phone software its 14
    and the web portal i assume its the current
  4. YiannisH_3CX
    May 10, 2016
    7,326
    532
    On the current V15 version you can navigate to the desired extension then to phone provisioning Tab and click the delete button next to the phone model. Then click ok
    On V14 go to the desired extension / Phone provisioning tab and delete the MAC address of the phone you want to remove. Also where the phone model is listed select the "Select phone model" option. Apply and OK
