Cisco SPA508g Multicast Paging Template
Discussion in '3CX Phone System - General' started by SeanBnd, Apr 30, 2015.
  1. SeanBnd
    Apr 30, 2015
    I am trying to add a multicast paging group to the cisco508g template. I used the the line below but it will not work.
    Code:
    <Group_Paging_Script group="Phone/Multiple_Paging_Group_Parameters">pggrp=224.0.0.32:10000;name=All;num=8009;listen=yes</Group_Paging_Script>
    Can anyone help me with the right syntax so I can add the multicast group to the template. It has to be added through the template since I'm using a modified template for custom names for parking blfs.
    Update: Got it to work. Had to edit it through Notepad++ and then make sure that the .xml files for the individual phones were being updated after I made the change. I did that by going into the extension properties in the 3cx manager and just pressing okay.
