Cisco SPA525G2 (notice the number '2' at the end)
Discussion in '3CX Phone System - General' started by Fatboy40, Nov 5, 2010.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Just wondering if anyone is using the Cisco SPA525G2 phone at all with 3CX ?.
    This model, note the '2' at the end, appears to be fairly new and has built in 802.11b/g Wi-Fi ! (the plain Cisco SPA525G is now end of life). I'm itching to get some remote extensions setup and I'd rather have a fully fledged desk phone like this than the WIP310.
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Talking about 'end of life' all the Linksys models are now as well...
    http://www.cisco.com/en/US/products/ps10033/products_eol_models.html
  3. coldtech
    Oct 5, 2010
    31
    I have 4 of them.
    Seem to work just fine.
  4. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Are any of them setup as remote extensions, for example at a users home, running over their WiFi network ? (so that NAT and STUN are being brought into the mix).
  5. coldtech
    Oct 5, 2010
    31
    No, sorry.
  6. leejor
    10,366
    227
    Setup should be relatively straight forward. I'm sure, that for the VoIP settings, you can use the SPA525g settings. The only difference is that WiFi has been added to the mix. Get that to work first, then work on the VoIP settings. As a "remote" extension, you will need to enable STUN, and be sure, if you are using more than one set at the same location, that each has a unique port number.
