Cisco SPA525G2 provisioning with DD-WRT flashed router (TIP)
Discussion in '3CX Phone System - General' started by FGCUHank, Jul 31, 2012.
  1. FGCUHank
    FGCUHank New Member
    Feb 27, 2010
    101
    Just wanted to share a couple of provisioning tips on V.11 with the Cisco SPA 525G phones when using a DD-WRT flashed router.
    Under Services\Services
    In the DNSMasq additional options at the following, don't forget the quotes as all hell will break loose on your DHCP clients.
    dhcp-option=66,"http://IP_OF_3CX_SERVER:5000/provisioning/$MA.xml"
    Under Setup/Basic Setup
    Make sure the DHCP-Authoritative checkbox is set
    Without this checked the phones would not auto provision, I had to set the path on each phone.
    Hope this helps
