Cisco SPA901
Discussion in 'Windows' started by imunro01, Dec 9, 2010.
  1. imunro01
    Dec 9, 2010
    Hi Guys,
    The SPA501 is listed as compatible, however I'm looking at the cheaper single line SPA901. Can anyone advise if this will work?
    Cheers
    11,105
    329
    I'm pretty sure that as long as it is a SIP (firmware) set, you should have no problem. A simple set, not a lot of options, has an even greater chance of working with any SIP server. Basic sets usually only require 3 things to get dialtone...Server address, User name (phone number), and Password.
    http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa_9X1_admin.pdf
