Clearone Max IP Conference Phone
Discussion in '3CX Phone System - General' started by 12494, Apr 24, 2011.
    12494 Member
    Apr 16, 2010
    306
    31
    Anyone have information on how to configure Clearone Max IP conference phone with 3cx?
    I'm trying to get one to work on my 3cx system. Actually, this was a Max IP Response Point which I had. I just put the current Max IP firmware on it. I've got it registered to my 3cx system. I can make a call and receive a call on it - but there is no audio once in a call. Do you have sample configuration for this device or other words of wisdom?
    Thanks,
    Allen Miller
  2. 12494
    12494 Member
    Apr 16, 2010
    306
    31
    Okay - I've got this unit working on my system.
    Thanks.
    Regards,
    Allen
