CLI and ISDN30 with Vegastream Gateway
Discussion in '3CX Phone System - General' started by BendyMetal, Oct 8, 2007.
  1. BendyMetal
    Oct 8, 2007
    36
    I am after assistance with configuring a 3CX (which is great by the way - thanks!) and a Vegastream 400 gateway. My problem is with CLI.
    Config in brief:
    ISDN30 --- Vegastream 400 --- LAN IF -> 3cx
    (nothing complicated about that)
    Dial plans all work - I can make and receive calls both internally and externally.
    I am using Polycom 330 phones and the latest version of 3CX.
    When I monitor the Vega, I can see the CLI tag coming through from the ISDN.
    -- What do I need in my dial plans to pass the CLI through to 3CX?
    -- What do I need to do in my 3CX system to see the CLI on the Call Assistant and/or the phones?
    -- Do I need to give any further details for any one to help?
    Any assistance is greatly appreciated! TIA.
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Try this, on the gateway configuration, go to Other Options, select "Use Ip in Contacts" and below input the Ip address of your gateway. See if that works...
    Cheers
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Please provide the 3CX console log and that device debug log. We will investigate your issue. We must know what's caller id at the SIP call from that device to 3CX box.
  4. BendyMetal
    Oct 8, 2007
    36
    Problem solved
    I realised on closer inspection that the CLI was coming through from the vegastream - 3cx caller id field is the "contact" field in our case.
    Thanks for the offers of assistance nonetheless!
    :D
  5. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Good to hear your problem had been solved.
