Click to dial form Browser
Discussion in '3CX Phone System - General' started by vectra, Feb 12, 2015.
  1. vectra
    Nov 3, 2009
    28
    Hi Everyone,
    is there any solution to have option click to dial from browser using 3CX CTI app on workstation? That should work same as Skype plugin for browsers.
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Yes you have different ways to achieve this :
    - define a shortcut in your 3cxphone settings, so that when you highlight a phone number in a page and presses the shortcut combination it will compose the number in 3cxphone dial screen
    - have a pro license and use the TEL protocol, this way any link starting with tel: is dialed in 3cxphone when clicked
    Those two options can be combined with CTI mode in 3cxphone so that whatever is input in 3cxphone will be dialed on hardphone.
