Click to dial from Outlook with 3CX System
Discussion in '3CX Phone System - General' started by luppas, Apr 7, 2013.
  1. luppas
    Apr 7, 2013
    For those interested in click to dial from within outlook
    I been using this nice little plugin http://www.theteletrigger.com
    Works great with my 3CX systems
  2. yaro
    Jun 11, 2008
    38
    I suppose I'd have to find a way to get rid of Skype's Outlook integration features first...
  3. luppas
    Apr 7, 2013
    Try disabling skype in the outlook addons sections or uninstalling it completely if you dont use its outlook features
  4. jasit
    jasit New Member
    Feb 12, 2013
    173
    I tried out the teletrigger and it works pretty good and I had to email their support because google would open up and nothing will happen. I got a quick response with a couple of suggestions. I found out that with the 3cx system, it says version 10 3cx but does work with version 11. The cool part is if you put the *9 infront of your extention number it will auto answer instead of waiting for you to pickup before it makes the call.
    jasit
  5. luppas
    Apr 7, 2013
    Thanks Jasit!
    I did not know about the *9
    That makes it much better
