Click to dial IE or firefox
Discussion in '3CX Phone System - General' started by jeremyn, Jul 7, 2008.
  1. jeremyn
    Mar 25, 2008
    42
    anyone know of a plugin for firefox or IE which will work with 3cx which converts a phonenumber on a page to a url that could be used with 3cx ?
    thanks
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Why do you want to do that?
    Is it possible to scrape the number into eg outlook and than use the outlook integration to dial the number?
    if you get the number into 3cx, all you have to do is adding the dial out prefix and it should work as a cut and paste having said that, save to clipboard might do the trick.
    H.
  3. jeremyn
    Mar 25, 2008
    42
    we would prefer users could go to a web page and simply click the number. skype has this function and I hhave seen some plugins for asterisk or other phone systems see
    https://addons.mozilla.org/en-US/firefox/addon/7961
    or
    https://addons.mozilla.org/en-US/firefox/addon/6423
  4. Henk
    Henk Member
    Nov 13, 2007
    250
    I assume so, Matt
    That is why i asked the question why they want to do that, if they have a CRM than perhaps there is some sort of address book they can use.
    If they use the web to scrape numbers for "cold calling" eg marketting than that is a different story.
    Non the less, interesting to see where this goes.
    H.
  5. jeremyn
    Mar 25, 2008
    42
    yes have a web based crm, however it would not be practical for someone to be looking at someones account then need to go to outlook look up their contact card to call them, we would like something which is seamless. ie they can just click the number
  6. broesder
    Jul 21, 2008
    9
    http://www.download.com/IpDialer/3000-2155_4-10640362.html?tag=lst-1&cdlPid=10640363
    A small but effective programm, select the number you want to dail, click your hotkey combination and it dails the selected number. Three hotkey combinations possible for three extensions! (for example CTRL-f1 = deskphone, CTRL-f2 = DECT etc...)
    Kind regards
  7. raffaeleguidi
    Aug 16, 2008
    Well, the simplest and elegant way to do this is just handling standard "sip:{user}@{domain}" links just like x-lite or sjphone. Or at least handling command line parameters (ie 3CXVoIPClient.exe sip:{user}@{domain}). This would be a feature that - together with the "execute application" on incoming call - who could make 3cx the more professional free softphone on the market.
    Regards,
    Raffaele
  8. FlightRisk
    Mar 29, 2011
    9
    TeleTools can do this. A lot of our customers think it is pretty important to be able to scrape numbers from an open window or open browser. As mentioned, Skype can do this, but it can alter the loading of the WEB page, so it is nice to be able to turn it on and off.
  9. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    search the forum -- there were some instructions how to use 3cxphone.exe with parameter to dial a number
    one of these posts is: http://www.3cx.com/forums/3cx-windows-dialer-21465.html?view-post=108150#p108150
    regards
