Click to dial
Discussion in '3CX Phone System - General' started by colintve, May 11, 2012.
  1. colintve
    May 11, 2012
    I would like to know if the 3CX system (maybe with Myphone) allows users to click on a phone number on a web page and have the phone dial (maybe right click and choose dial).
    I had this system with my old system and Skype has it, but I can't see how to do it with 3CX.
    Is it possible?
    I had a programme called Callclerk that does it, but its a bit of a messy workaround, especially if 3CX can do it
    Thanks.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    I was able to create an IE 8/9 plugin that I install when I provision a phone for someone - static ip.
    Then when they right click a phone number and select the plugin it calls an ASPX web service to make the phone (Yealink) make a call to that number. You can't just to an http call because you have to pass username/login for the phone and ie9 prevents that.
  3. colintve
    May 11, 2012
    That sounds great, so I assume that 3CX doesnt offer it then, shame.
    Could your plugin be made available and modified to work with other phones?
    I am not a programmer, so would not be able to do it myself.
    We are planning on using Gigaset DE900 phones with the 3CX system.
    We all do use IE9 and have static IP for each phone.
