Solved click2call - dial 9
Discussion in '3CX Phone System - General' started by GBC_James, Jun 23, 2017.
  1. GBC_James
    Feb 3, 2017
    59
    6
    running v15.5
    We have an outbound rule requiring everyone dial 9 to make an outbound call, pretty standard stuff.
    however, click2call plugin in Chrome doesn't add the 9 to the numbers being clicked and so call fails.
    Same in Outlook integration. Any external contacts with phone numbers fail because the 9 is not being added before dialling. (we could get everyone to edit their contacts adding in the 9 manually, but this doesn't help with web page click2call)
    I have a feeling I am missing something very obvious but I can't see it.
    Any help?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,425
    352
    Hello @GBC_James
    Please note that you will need to create a different outbound rule for those numbers that you dial through Click2call as these numbers will not match the current outbound rule.
    You can use number length or extension group to define the outbound rule.
  3. saqqara16
    Jan 13, 2016
    43
    5
  4. GBC_James
    Feb 3, 2017
    59
    6
    Thanks YiannasH_3cx and saqqara16
    sometimes you can't see the wood for the trees :)
    I tried making a new out bound rule but if failed. guess why? I told it to prepend the number with 9! Which of course would fail because I have just created a rule to get the dialled number out, so then putting a 9 on the front makes it an invalid number :rolleyes:
    Sometimes you just need someone to say "try looking here" and the penny drops :)
  5. YiannisH_3CX
    May 10, 2016
    5,425
    352
    Glad to hear it is working now :)
