ClickToCall Chrome Extension Not working properly
Discussion in '3CX Phone System - General' started by joemailey, Jun 24, 2017.
  1. joemailey
    Jan 3, 2014
    25
    So I've just upgraded to v15.5.
    I've installed the click to call chrome extension
    Configured it to use the web client.
    I can click on my mobile number via our CRM.
    My desk phone rings(Yealink T29G)
    It displays "Make Call"
    I pick up my desk phone
    It still display Make Call
    My mobile rings for split second and then the call stops and my deskphone just remains on "Make Call" with my on hold music playing.
    I'm assuming 3CX should release the make call and my desk phone should begin ringing my mobile, but the make call never gets release/forwarded.
    What am I doing wrong or what do I need to change for this to work??
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,252
    203
    Is the phone running the require firmware
    Click on 'Phone' on the left, and will tell you if the phone requires a firmware
  3. joemailey
    Jan 3, 2014
    25
    The yealink as far as I'm aware is running the latest version of firmware available: 46.81.0.61.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,400
    535
    Hello @joemailey
    The firmware you are running is the supported one for your phone so please make sure that the phone is provisioned with the latest supported template as well which enables the uaCSTA that the web client uses. Make sure that you have downloaded the latest template from the updates section of the management console and that the phone is provisioned using that.
  5. joemailey
    Jan 3, 2014
    25
    How do I know if I'm using the latest template???
  6. saqqara16
    Jan 13, 2016
    46
    7
    Under 'Updates' it will tell you any templates that need updating
  7. joemailey
    Jan 3, 2014
    25
    I know that I've all updates downloaded, I was wondering from the yealink's point of view how can I tell.
  8. joemailey
    Jan 3, 2014
    25
    re-provisioned the phone and it seems to be happier. Thanks for the help.
