Client 3974: NetworkConnections hanging => 3cxTunnel.exe
Discussion in 'Windows' started by Tugi2o, Jan 31, 2008.
  1. Tugi2o
    Feb 20, 2007
    61
    since i've installed the new Client 3974 on my WinXP computer, sometimes it happens, that all my network connections are hanging.
    So Outlook tells, that it has no connection to the exchange server, and InternetExplorer has also no connection.
    After killing the process 3cxTunnel.exe everything works fine.
    With the older version i never had such problems.
    Do You have the same experience?
    PS: i use 3cx software all over the day ~12h
  2. ktikoft
    Jun 22, 2007
    59
    I am seeing all my browsing hang on the two machiess i have put it on which had the previous beta running with no issues as well.
    My local network stuff seems all fine an d3cx is also on my local network.
    Sounds like a mojor bug here
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    304
    Yes, we have found this and it has been fixed in latest version 4034
    Apologies for the inconvenience!
  4. darrellchapman
    Nov 26, 2007
    268
    Glad to know it's fixed. Just today I identified this executable as the source of my problems with Internet. Killing the process would restore Internet connectivity.
  5. darrellchapman
    Nov 26, 2007
    268
    Actually, I just confirmed that this is still a problem with 5.1.4034. HTTP traffic seems to function correctly but POP3 (port 110) traffic is being blocked.
  6. darrellchapman
    Nov 26, 2007
    268
    This is no longer a problem in build 4132.
    Darrell Chapman
