Client avilable , in 3CX he is not
Discussion in '3CX Phone System - General' started by foulad, Nov 17, 2013.
  1. foulad
    Nov 11, 2013
    23
    Good day,
    please check the attached snapshot , all my clients available in the clients PC and not on the 3CX server ?
    11,095
    327
    "Available" doesn't mean registered. You need to look over the logs and determine why the extensions are not registered.
  3. foulad
    Nov 11, 2013
    23
    the below log im getting
    17-Nov-2013 11:31:10.381 L:50.1[Extn] forwards call from Extn:100 to VMail:999 based on rule Fwd[Available/NotReg]
    17-Nov-2013 11:31:10.381 L:50.1[Extn] failed to reach Extn:100, reason Not Registered
    17-Nov-2013 11:31:10.381 [CM503017]: Call(C:50): Target is not registered: Extn:100
    17-Nov-2013 11:30:33.716 L:49.1[Extn] forwards call from Extn:100 to VMail:999 based on rule Fwd[Available/NotReg]
    17-Nov-2013 11:30:33.715 L:49.1[Extn] failed to reach Extn:100, reason Not Registered
    17-Nov-2013 11:30:33.715 [CM503017]: Call(C:49): Target is not registered: Extn:100
    16-Nov-2013 22:34:15.138 [CM503017]: Call(C:1): Target is not registered: Extn:100
    i dont know what is the issue ?
  4. foulad
    Nov 11, 2013
    23
    ok i find it out
    from Extension , 3CXPhone Tap ,
    configure default phone to use in 3cxphone for windows , check it and select Inbuilt softphone
